Ralphmp
I have 2 points on my layout where tracks converge and yesterday it was purely by luck that a minor bump between 2 trains didn't turn out to be a major catastrophe.
To avoid a repeat, I'm trying to figure out how to create a system which ensures that if the points are set against an approaching train, the train stops safely.
As I see it, I have the following options:
1. Only run one train on my layout at once - foolproof but not very appealing
2. Create isolating sections of track ahead of the points, and use a supplementary switch (LGB 12070) on the points to turn off the power to the track that the points are set against - simple to install in theory, but as several of my locos have power buffers, trying to decide how long to make the isolating section would mean a fair bit of fiddling
3. Use a track contact + feedback module + the Massoth Autodrive feature to issue a "Stop" command when a loco approaches the points that are set against it - I like this concept as the loco is specifically told to stop, rather than relying on being deprived of power. I can also avoid the Stop command being actioned every time a loco passes the track contact, even when the points are set correctly, by using a 12070 switch to ensure the Track Contact is only powered up when the points are set against the approaching loco.
However, there is a problem with Option 3 - it looks like there is no "generic" loco address I can input to the Autodrive command sequence so that the instructions are processed for every loco. As I understand it, I have to set up a specific Autodrive sequence for each loco address, and there is a limit to the total numer of Autodrive sequences I can store.
There may also be a further option using different types of sensor to detect a loco and issue the Stop command but my only experience is with Massoth kit, and not being an electronics whizz I don't have the knowledge to figure out the individual components I'd need to build my own solution..
I'd be interested in any suggestions and hearing how other folks have tackled this issue. I'd also welcome comments on whether my assumptions on what I can / can't do with my Massoth kit are correct.
Thanks in advance
Thanks in advance
