chris m01
I use the old Aristo train engineer for track power and a Deltang tx22 with Rx65 receivers for my battery fleet. This is all fine and I am very happy with it.
I am aware that one day the train engineer will give up on me and I like the knob control on the Deltang (or RC Trains) transmitter. So, based on comments in previous threads I bought myself an Mtroniks 24volt Viper HV ESC which I plan to use to provide power to the track. I have a couple of technical questions.
1. So far I have tried it with a DSSS standard radio control TX and RX to control track power and it worked exactly as expected. I then connected an RX65 receiver in place of the standard radio control receiver using P8 as the trigger for the ESC and using the power from the ESU to power the RX65. The RX65 is bound to a TX22. This works but sometimes there is a delay in power being applied when the knob is first turned. Once the power comes on stream control is perfect. I'm not sure whether there is something built into the servo output on the RX65 to prevent switching too quickly. This delay does not occur when using the DSSS TX and RX. This isn't really a problem as all I have to do is apply wait about five seconds from stopping before starting again but I wonder if this indicates some sort of technical issue which could be a problem later.
I'll post the second question in minute
