Hi all
I am yet to start the build of my first garden railway and I am the stage of deciding to go the MTS or analogue route. I have managed to acquire the LGB digital starter set with two chipped loco's and the controllers (albeit no wiring in the set). I know the main thing against MTS is going to be the cost of installing decoders in my other loco's, and indeed the extra decoders needed in my power/sound tenders I have. I suppose what I am asking is those of you that went down this route.....are you happy you did so, or would you of rather stayed with analogue?
In the first instance I thought I could control points etc via a control panel with standard normal switches etc and then maybe later on update to digital (as and when costs allow.........or I can sneak some gear in past the boss!!!)
Also (might as well get the questions in while the space up top is in thinking mode!!), are MTS systems reliable or will I be forever changing decoders because of faults etc?
I hope to eventually have approx 300-400 feet of track in operation ( and blue pigs will also fly over Wales at the same time!!), so will I have to place several power feeds into the track further up the line to stop power drop.
I thank you in advance for any advice you can give, and although I have no railway yet I can at least bore you with site pictures later on so you can all tell me I am mad, as it is a bit steep .......but I do have two Rack loco's at the ready.
Kind regards to all
Kev
Kind regards to all
Kev
