Hello all,
     firstly a good thread with lots of nput form some very experienced moddlers, Compared to peolpe like Maybach I am amateur but here is my 2 pence worth.
     I use rattlle cans, I treid an airbrush, all be it with aerosol gas but had many problems getting the piant to the right consistance. also the amount of effort to clean all the air brush out after every use drove me nuts and added an hour on to every task.
     I tend to use rattle cans, esp those from car stores such as Halfords. I have also used some of the model specific ones for Rail blue when halfords do not match it.
     +Firstly Make sure your model is clean with no dust. do not use fairy liquid.
     + mask all area you don't want to be sprayed, low tack tape, and maskol for the windows.
     +Warm your primer and the room / garage your spraying in.
     +Always use the appropriate primer, For plastic I use halfords plastic primer, for bare metal I use acid etch primer. If the surface is very glossy rub it with some 800 grade paper,  this will allow the primer to key to the surface.
     +When spraying the can should be about a foot (12") away from the model, too close and you'll get runs, too far and paint atoms may start to dry before adhering to the model. I never start spraying directly at the model, Start off to the edge away from the model and once your spray has started then move the spray on to the model.
     +Wait, 24 hours minimum, use this time.
     + Once the primer is dry. Repeat the warming steps. Then its time to paint, make sure can is well shaken, and warm, again start spraying slightly away from the model until the spray actually starts. Once the spray steam has started gently move this towards the model. Follow the same principle as the primer, about a foot. It'll take some practice as all paint brands differ slightly in their consistance and therefore may run in different circumstances.
     + I usually build up 3 light coats, with the model on a lazy susan (ikea £5.00).
     +Wait about an hour before removing the masking tape.
     +wait about a week for paint to harden pick a varnish, and repeat the process again with varnish.
     questions that were asked: do I re apply the masking tape each time. Nope I leave it on through the painting stage otherwise I may add it slightly different each time. (maskol advises not to leave it on for more than 48 Hours).
     Like I said I'm not as good as some peope but I do use rattle cans and I am happy enough with my results. Here are a few threads where my use of ratttle cans can be seen:
     PIKO 218 using railmathc spraycans. Slightly different and more aggressive spray than halfords, but with practice got a decent finish:
http://www.gscalecentral.net/tm?m=5793&high=PIKO+218
     LGB LCE using halfords red, and silver:
http://www.gscalecentral.net/tm?&m=33700&high=LCE&mpage=4
     My current unfinished ML4000 project agian using halfords spray cans:
http://www.gscalecentral.net/tm?&m=73453&high=LCE&mpage=2
