maxi-model
I have a recently aquired 2nd hand electric Acucraft K-27, it has Sierra Soundtraxx card fitted. I accidently pulled off the smoke box front the other day. When I replaced it the head and marker lights no longer functioned in forward motion but the rear tender mounted light, only, still functions perfectly when the track current is reversed. I checked the wiring on the small circuit board, looks like Accucraft's standard 6v voltage regulator assy', mounted in the smoke box and the only thing amiss was one of the legs on the cylindrical object ( sorry I have virtualy zero understanding of these things other than simple wiring) on the board had come adrift. I soldered this back into what appeared to be the correct position on the board. But still no front head/marker light function. All the wiring to the head and marker lights seems ok with no breaks. Any ideas what is going on here and what I might need to do to fix ?
I include an image to aid with identification of components. I would much appreciate your ideas on what I need to do to fix. I'm wondering if I need to replace the lights wholesale or might one of you eletrickery minded souls have spotted something like a diode thingy that might need replacing. Max.
