A brewery for Beeston Castle
ge_rik
Having recently added another siding to Beeston Castle station, I decided to use the original short siding for access to a brewery. After searching the net for a suitable prototype, I eventually decided to base mine on the Metcalfe 00 card kit (now no longer available), as it's fairly generic and I couldn't find a decent picture of a real brewery.
Because it's a bit of an awkward site, I initially made a mock-up from corrugated card to see how the model might fit.
This gave me the courage to mark it out on to sheets of 5mm thick PVC foamboard, my preferred building material thanks to Mike of this parish.
And then the fun began. Scribing the bricks. I decided to go for stretcher bond as this was the easiest to mark out - but I reckon there are somewhere in the region of 2-3000 bricks on the finished structure.
It is quite therapeutic, provided there's something interesting to listen to on the radio. Anyway, now finished all the scribing and the structure is taking shape.
I am in the process of adding slates to the roofs. The canopy and lucams are done (but need detailing), but I'll add those once I've painted the brickwork. Looks like the rain / snow has stopped so might be able to get the primer coat on today.
Rik
That's got something of a Harry Potter look about it Rik. I quite fancy a Hogwart's in the corner of my garden.
Excuse my ignorance, but what are 'lucams'? The sticky-outy bits?
(Noun) A structure in the roof of a mill that projects out from the building to allow the hoist to winch up sacks clear of the mill and give protection from the weather.
Thanks. Couldn't have put it better myself.
Rik
Rik
Looking Good Rik. I reckon your estimate for bricks is a touch out, I've just finished working out for a full size single garage and there are 7000ish in that. Take the hyphen out you'll be closer! :giggle:
Looking Good Rik. I reckon your estimate for bricks is a touch out, I've just finished working out for a ful size single garage and there are 7000ish in that. Take the hyphen out you'll be closer! :giggle:
You're quite right. I'd forgotten that it was the calculation for just one section. Just re-calculated and it comes to just under 8000. There's no back to the building otherwise it would be around twice that number. I think my bricks are slightly larger than the real thing.
Rik
Rik
It'd be good if someone produced foam-board with the bricks (or stones for that matter) already printed on! :eek:
On second thoughts, it might put Mike out of a job! :rofl::rofl::rofl:
Need a second look at Mike's latest.. - It looks like he might have found an embossed sheet for the back of a building? - Or a trick of the light /my eyes! :nerd:
I think it's Fantastic,
Rik
Rik, looking at the original Metcalfe Kit I do not see a High Level Water Storage in your build unless the Square High part in the pics will have it. Quite an important element of the product! Nice start to what I am sure will be a good traffic generator / receiver on your line.
Hi Jon
I think mine might be off-scene. When I position it, there might be a bit of space at the back of the right hand roof for a glimpse of the tank.
Rik
Made a bit more progress with the brewery. Slow but steady on this one - there are a heck of a lot of bricks and I ended up painting most of them individually after a cock-up with my dry-brushing. Anyway, still a bit more work needed (painting the canopy, ridge tiles, doors, windows, barge boards, guttering and a bit of fine detailing), but she's beginning to look the part.
249064249065249066
I've got bespoke 3D printed windows on order from this chap - 8 off Factory window frames.3D printed 22 mm x 38 mm,Others available to order. | eBay
£1 each, plus £4 for setting up the printer for my dimensions. Seems like good value to me.
Will let you know what they are like when they arrive.
Rik
Well, it's taken a fair while, but at last I am nearly there!
Lettering courtesy of 'The Works' - £1.50 a pack of laser cut ply letters (2 complete alphabets per pack)
Windows, doors, guttering and downspouts now in place (the downspouts were a bit of a mare).
And now test-fitted in its location at Beeston Castle station.
Had to cut back the hedge a fair bit and also prune the model a bit to make it fit.
Need to bed it in properly with a concrete plinth and the track will need to be realigned slightly. Inevitably, there are a few more detailing and touching-up jobs required, but it's more or less complete.
Phew!
Rik
Excellent build, Rik! :clap::clap:
Tell me, will it fit in a 750mm square footprint?
And,
Will it be going to Nottingham? :think:
