Having been tempted into G scale the Newqida Harz 6001 look-a-like and then moving on to the hard stuff, I soon got fed up with the blue front headlamps, so off to an electronics shop, buy 2 white led's and swap them over, no problem!!
Well I took the lamps off and looked at the front end...Hummm, it's a bit fat me thinks, don't like the buffer beam...Hummm, So off with the front pony truck, out with mister hacksaw!!
After a bit of chopping and muttering
Better, but need to sort out that coupling hole...Hummmm
A bit of wood glued in and the coupling end shortened, so the loop swings enough for R1's if needed (have sort of set R2/3 as minimum) and built up a new laminated plasticard buffer beam,
Just now add the air brake pipes, the vacuum ones removed and maybe a steam head pipe and job done.....errr well, not so, those lamps I was on about... well....,
see the led's I got don't work, so can anyone help??
As the saying goes, When your up to your arse in crocodiles, it's hard to remember the original objective was to drain the swamp!!
Pete
oh yes, there's the cab roof vent is as built and the front 2 side cab windows are a bit big, oh and that rear buffer beam..........
Pete
