If you could let me have the size of the LGB hoses, I will happily scale the print to match. Probably need height of the fitting, plus approx diameter of the hose.Nice, are these a similar size to the LGB vac hoses? If so, I will take a set please
Nice, I will have a look when I'm home tonightIf you could let me have the size of the LGB hoses, I will happily scale the print to match. Probably need height of the fitting, plus approx diameter of the hose.
I'm missing some hoses on one of my Wizzy Cranks locos. It should have 4 but I only have 2.If you could let me have the size of the LGB hoses, I will happily scale the print to match. Probably need height of the fitting, plus approx diameter of the hose.
I'm more than happy to take a look. Do you want to send me a private message and I can let you have a postal address etc.I'm missing some hoses on one of my Wizzy Cranks locos. It should have 4 but I only have 2.
Could you print me some if I send you a hose please? They are different to the ones found on LGB wagons....
PM incoming....I'm more than happy to take a look. Do you want to send me a private message and I can let you have a postal address etc.
Posted today, so should be with you Tuesday.Look forward to receiving my sample soon....
Sounds like a good idea, likely I will spray undercoat grey then matt black, then some subtle weathering.Even though they are already black, you might want to paint them to create a layer to block the UV rays from the photosensitive resin, so they don't get too brittle too fast in sun light.
