24V 15A trafo
Dutch willy
I do have a home build 15A trafo (2x7.5A) that was build into a VERY cheap toolbox .
Friday the post delivered a makita toolbox ., its a older type and it was dirty :(.
After cleaning , it was time to demolish the old one :).. en build in to the makita toolbox .
We did have a old Minion travel case witch was broken , so i take the advantage to use the front and side vor a cover , because the Trafo is for the children .
its a simple trafo , 24V 15A split in to 2x7.5A , with for and backwards function and speed control .
if necessary it can be split in to 3x5A .
Total cost of this trafo was 25 euro ..and a view hours time on labor , a 5A or 10A jumbo are very expensive.
The quality my not be so good as LGB piko ore others , but it.s save and wil do the job
13902691_661539763993216_3740386605774156829_n.jpg 13906734_661539777326548_1695647645875820214_n.jpg 13892207_661539797326546_6771134299340447574_n.jpg 13903262_661539840659875_7962765881747673677_n.jpg 13921051_661539877326538_6868755784931542074_n.jpg 13912476_661539897326536_1612723099118180989_n.jpg 13912811_661539920659867_6013714222387222728_n.jpg 13895387_661539937326532_6277369180307196262_n.jpg 13895088_661539967326529_8646138288416687936_n.jpg 13873035_661539983993194_1568729582890321157_n.jpg 13882286_661540030659856_1928862470767099795_n.jpg 13886952_661540050659854_4689751206016505411_n.jpg 13902747_661960340617825_9003855912720675110_n.jpg
And a smal video .. easy to set up , and quikly to out a way .
