I've been trying to charge up one of those blue 12v Li-ion batteries from China. I'm using an Imax B6 balanced charger which I've used OK with another of these batteries. It's a new battery - never used.
When I try charging up this one it works OK for a while then after anywhere between 30 secs and 2 mins I get an error message 'Connection break'. I've checked all the connections and there does not seem to be a problem - and have now tried the same settings with my other blue battery which is now happily charging.
Looking on the web it seems I am not the only one to experience this problem and one suggestion is to open up the battery and check and then if necessary re-solder the internal connections. I'm not too sure about this. Has anyone else had any experience of this problem?
Rik
Rik
