A buddy of mine 3d printed replacement trucks for me for my Connie water tender successfully, but he's moved abroad somewhere, somebody else must have printed such trucks I'm sure of itI haven't, as I thought the side members wouldn't be rigid enough. Cast whitemetal and injection moulded polymer have rather different characteristics from ABS and PLA, which I found to be a bit 'short', i.e. prone to fracturing. But things may have moved on, as I haven't done any 3D printing since before Lockdown 1.
Thankyou for the info, could you suggest some 16mm websites for me as I wouldn't know where to start.I think the problem Paul has had, was similar to mine and a few others. A faulty batch of Mazak castings that afflicted a run of Bachmann Spectrum 1:20.3 rolling stock, produced a few years ago. The issue was delt with for Stateside customers who flagged it to them at the time. Those lucky few got free replacement parts then but this problem of the offer of replacements was never, seemingly, communicated to their distributors in other territories. Like the UK/EU. By the time one of my boxcars started failing, broken truck frame, it was too late to get replacements. And the evidence had been disposed of.
Over time the other truck failed, all side steps, a bolster and (just a couple of weeks ago) a coupling shank. I have managed to replace these with, respectively, Accucraft, Ozark whitemetal reproductions, bitza Accucraft/Bachmann remains bolted through to the boxcar's floor and a USAT coupler suitably modified. All bar the Accucraft trucks and sidesteps were sourced from the "bits box". Never throw anything away, you never know how and when they may become useful with a bit of resourcefulness.
Paul, you might want to check some of the UK 16mm offerings. There are some items out there, that are supplied or can be regauged for 45mm use, that offer a fair approximation of the US style item. Max
Edit - Just checked the Bachmann site. Chargeable replacements are still available Truck - Dark Brown (G Spectrum Rolling Stock) [G880X-00G03-DB] - $48.24 : Bachmann Trains Online Store!
Have a look down the list of suppliers. Useful Links - Association of 16mm Narrow Gauge ModellersThankyou for the info, could you suggest some 16mm websites for me as I wouldn't know where to start.
Please
Hi igor. Thankyou for the info,, my problem is I have no printer and I was hoping to find someone who wouldn't mind printing me a setI printed several of them, but most i printed (100+) are soviet.
They work really well without any bearings just some wd40 on the axle and some in the axle box.
I even did some experiments with different type of oils, greases and fats.
Even after a month outside in hot cold very dry and very wet wheater wd40 beats them all
My boogies revisit them
Corona give me two things: a positive test and some time off I made some changes to my boogies, a lot of changes, for smooth operation. The most important ones where give more side to side clearance, making the journals(axle box) deeper and thus the axle longer and the use of some lube. The...www.gscalecentral.net
Sorry i was not able to dig out my first thread about making them.
On thingyverse you will find also some usa style bogie's but some have really to big couplers?
With best regards Igor
