Zimo MX820D A Tiny Waterproof Switch Decoder
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
I have been looking for a small switch decoder and came across this from Zimo. It`s an update from their MX 82 decoder with some interesting additions.
It is designed to switch one output but is capable of switching two motors together as it`s rating is 3A and can cope with a maximum of 40v track voltage.
Waterproofing is achieved by shrink wrapping and then resin filling.
If you want to install inside an Lgb Epl drive it`s small enough to fit where the supplementary switch usually goes or if you want to use a switch like I do it will sit in place of the screw connections and be connected directly.
An additional useful feature are the connected switch input wires which trigger the drive by applying a positive voltage to a single wire.
A Massoth sense track section feeding the decoder track voltage is ideal for this as a solid state alternative to reed switches or track contacts.
You can also use the outputs to switch a two aspect colour signal instead of an EPL drive.
ntpntpntp
275
UK
United-Kingdom
Very interesting. They're smaller than the NCE Switch-Kats I normally use.
How much are these little chaps? My last bunch of NCE Switch-Kat's were about £14 each (plus cost of a small project box and some sealant) but that was a while ago.
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
They came in at £24 each Nick which given the size, waterproofing and features I thought wasn't too bad.
ge_rik
1,247
Cheshire
www.riksrailway.blogspot.com
I'm used to the LGB decoders which basically have two input wires and two output contacts. What are all the wires on this one for?
Rik
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
There are are two wires which are one each each for the switch inputs and the blue is the common positive for when you use the decoder for colour light signals Rik
The manual is here
http://www.zimo.at/web2010/documents/MX820E.pdf
