Y point
Garden Railway Specialists in Princes Risborough do a nice wooden sleepered one, 6ft radius, 45mm gauge, uses LGB code 332 rail. Usually from stock. You need to add lever/motor to siut. I think they do a 32mm version and other rail types. There are other bespoke track makers such as 301 who will make them to order too.
Max.
Depends what radius you want?
I believe you can get a No 6 Y point from Aristocraft.
Piko are supposed to be producing a smaller radii one, eventually....
Or make your own?
The current LGB 3WP is R1 but you might be able to find the older R3 version 2nd hand.
I have one of each example on my own railway....
It ain't R3 Gizzy. Much sharper than that.
[quote author=stockers link=topic=298676.msg313001#msg313001 date=1397905617]
It ain`t R3 Gizzy. Much sharper than that.
[/quote]
I refer the honourable gentleman to my post #7.
The current LGB 12360 is R1 30 deg, but if you can find an older version LGB 1235, you will find it is close to R3 22.5 deg.
The one I have is part of a crossover at Sheringham South Junction with an R3 RH point and works well. See the photo below.
I also have the later R1 LGB 12360 version in Weybourne Yard which came via Gareth (3 Valve)....
