Beddhist
Motorcycle travel, trains
ROSS said:CREOSOTE. Now banned in the UK and the substitute is crepe.......
Hmmm, assuming you are not referring to the pancake, is it the paper, fabric or rubber? ???
Not sure about that one.. There is stainless steel, and then there is stainless steel!Madman said:I would think that stainless steel would be OK
I just looked at that URL. It would appear that there are no checks made on the credentials of the purchaser..... It just states its for professional use, if you use it in a professional manner who is going to say otherwise? I mean an amateur would not buy it - they would not know what to do with it.... Cheap enough too! I would take simple precautions while I was using it though to avoid prolonged skin contact..... Its really the only product that actually does what its claimed in this field.... Unless you can get hold of some Copper Napthanate.....ROSS said:So then....
In July 2003, it became an offence for the general public to purchase and apply Coal Tar Creosote. However, the product is still available for sale to trades-people. This means the traditional user such as the agricultural community, builders, etc. are still able to purchase Coal Tar Creosote, providing they do not resell to the general householder.
It is the responsibility of the purchaser to ensure that only genuine trade’s people/professional users are supplied.
- See more at: http://www.creosotesales.co.uk/#sthash.LuIKiluz.dpuf
Find yourself a friend in the trade...........!!![]()
PhilP said:Not sure about that one.. There is stainless steel, and then there is stainless steel!
We are talking an 'acid' effect here.. You get a green 'bloom' from a new oak/brass installation, which calms down as things age.
I would quite often pilot-drill, then use a steel screw to form the thread, and finally replace with brass. - that way if things are a little tight, you do not shear a brass screw!
Especially easily done in these days of power-drivers!!
That's neat! I like the sound of that - clever and has a traditional feel to itNorthsider said:White (English) or Brown (European) oak would be a good choice -the latter will be cheaper. Tannin in the oak will produce a blue/black stain where the wood is in contact with water and steel, therefore use brass screws. If you don't want to open out the holes with a steel screw, use the old joiners trick: drill a pilot hole in the wood equal to the core diameter of the screw, then run a piece of candle wax along the screw; as the screw goes in, friction generates heat, melts the wax and lubricates the screw. Bingo!
Madman said:On the issue of using Oak. Be sure that it is not Red Oak. Try to get White Oak.
Cedar would have been good. I believe it lasts forever (well near enough). Not sure of a source over this side of the pond.Ron Oyer said:I used Western red cedar for my bridges which I got from a great vendor on EBay. He has a store there NWP Model RR Lumber and Hobby Woods
