Warped Rack Rails
Ger-Y-Nant
LGB, Automation with DCC
Bridgend
Looked at my rack railway this morning and the rack rails have gone all bendy!
I assume this is caused by the cold we've had recently, but do they always go through this? Am I going to have to regularily re-lay the rack rail, or is there a trick to laying them so they don't bend?
Cheers,
Andy
steven large
USA G SCALES OF 30 TO 50S THEMES.ASLO KIT BASHING
15 Dec 2009
6,015
can u take a photos of it mate as i wud like to see it to cause what is the problem?..yes same as me got bend as well!!!!! in the middle of the track on rockie creek!!!!!
mike
Master at annoying..
4,467
Rossendale
Cheers,
Andy
they do at 1st.. it also helps if uve spaced the clips out , ie 2 per section, 3 on a curve.. i found that if i clamp it and pulled the kinks out, after a week , it setaled down..
Ger-Y-Nant
Bridgend
Here are a couple of photos of my problem.
When is best to re-lay the rails, when it's warm or when it's cold? I suppose warmer is better as the rails will have expanded?
Cheers,
Andy
themole
tramways
32
In a burrow.
When I had a rack line some years back, warping occurred often after warm weather.The trick was to release the rack and adjust. The rack would be ok until the next spell of warm weather, I fitted more clamps and the problem wasn't as bad. Alyn
mike
4,467
Rossendale
images
images
Cheers,
Andy
as brusce has said , you really need more clamps, and to re lay it, set the clamps every 5 sleepers, or what you think best , as i said, i ened up with 2 clamps on ever section off rack, and 3 when it curved.. it still distorts , but not enought to disrupt running..
Ger-Y-Nant
Bridgend
I've stretched it out again and all's fine again, so I'll see how long it takes to go wiggly again.
Thanks for the advice, looks like I may have to get some more clamps...
Cheers!
steven large
15 Dec 2009
6,015
u doing good job sort this out........wink.......
stevedenver
255
yep-just had this happen to me as well
0F frigid weather then up to 50F
a few bends-pull up gently to open the clamps and adjust and press down
do this when its warm to avoid damaging the rack rail connections etc-they will break sometimes unless youre very gentle and even with pressure
