beavercreek
The old Aristocraft Train Engineer receivers (RX) handled the voltage from the transformer and sent the required voltage to the track depending on what the handset Transmitter (TX) had told them to do.
They had an onboard switch that gave the option of straight 'linear' DC (much like that from a battery)..... OR .... PWC (PWM) voltage
The motors did not see the 'background' PWC pulse as it was too high frequency for them to react to but it meant that the constant pulsing voltage was great for most lighting circuits as the loco lights came on fully bright, even when the output from the receiver was low (unlike with linear DC where the lights tended to come on dimly at about 4 to 8 volts and might only be at full brightness at about 12v.
But as Greg has said, it was not good for sound systems, but also some USA Trains lighting circuits and certainly not for DCC locos which could react very badly indeed!
The problem is that the old Train engineer, although a good system was working on 27mhz and the new Train Engineer Revolution came along with 2.4 Ghz BUT now the track-side receivers do not have the linear/PWC switch so you have to buy either a linear or a PWC version.
If you buy the PWC version of the receiver (RX) and have a switchable linear/PWC converter you can then have the best of both worlds.... have nicely bright lights...or... run sound equipped or DCC locos on linear.
BUT..... I always found that Phoenix sound boards (2K version and upwards) were fine with PWC DC, most probably due to the fact that they work on DC or DCC and were designed to work with linear or the PWM output from a DCC decoder.
I have a strange feeling that maybe I may be corrected on this though.........
