Over in the topic http://www.gscalecentral.net/tm?high=&m=94204&mpage=1#95588
Bigjack was asking about potentiometers, resistors and diodes for reducing train speed. Del Tapparo made a comment about using these types of items to reduce speed, ?uses more power and reduces run times.? I presume he means compared to pulse width modulated type speed controllers.
I don?t means to criticize Del, but we have to be careful what we are comparing here. In actual fact, reducing the voltage using diodes or resistors, will NOT reduce your running time from a single charge very much at all. (That?s if we?re talking about reductions in voltage of only say 25% )
Using a PWM system will INCREASE your run time if you run at a lower voltage, compared to what you get at full volts.
It?s not that you LOSE runtime by using a resistor/diodes but you GAIN runtime by using a PWM controller and running slower.
WHY IS THIS SO???
Well a train motor is pretty much a ?constant current? type of load. If you take a given train on a given bit of track, it will take ABOUT the same current irrespective of voltage. Motors don?t act like resistors where doubling the voltage will double the current. The current drawn is a function of the load ? train drag, gradient and loco efficiency. The voltage just sets the speed.
That doesn?t mean the current never varies ? it will if you make your train heavier or send it up a steep grade.
If you don?t believe me do your own tests. The current may increase a little with voltage, but not much!
So lets imagine a given train taking 1A on a given piece of track powered by a 2Ah, 10V battery. It will run for 2 hours (2Ah/1A) and the battery will have supplied 20 watt-hours of energy to the train.
Now lets put a 2 ohm resistor or 3 diodes in series with the motor. It will still take 1A (maybe a tad less). So we?ll have 2V across the resistor and 8V across the motor. It will go slower (around 80% of original speed), BUT the battery is still supplying 1A and the train will still run for 2 hours. Sure energy is wasted in the resistor ? 4 watt-hours and the motor only gets 16 watt-hours. The energy used by the train is less because it doesn?t travel as far, but it still runs for 2 hours!
Now lets use a PWM controller to reduce the battery voltage to 8V. PWM (pulse width modulation - means that the supply to the motor is rapidly turned on and off, maybe 1000 times a second or more. The ratio of on to off time determines the average voltage that the motor receives.)
In this case the motor is turned on for 80% of the time and off for 20%. During the off time the momentum of the train keeps it moving and we don?t notice it?s going on-off-on-off??
So while the motor is on it takes 1A again, but the average current taken from the battery is only 0.8A, and the average voltage on the motor is 8V. It goes slower. BUT now we can run our train for 2.5 hours on a battery charge! 2Ah/0.8A=2.5 hours. It will cover the same distance as a full voltage train.
So a couple of diodes and a switch to short them out, costing a few dollars or pounds, can give you a speed reduction without reducing run times.
WHY IS THIS SO???
