paul delany
Hi folks anyone here ever fitted a revolution receiver into a sd70mac ,I am not sure how to wire the lighting section ..
Any help appreciated folks.
Hi Philip can you expand a bit on your advice for me pleaseOne way to do this :
Disconnect the smoke unit from the original board.
Use a DPDT relay.
Feed this with your battery supply, and arrange it as a reversing switch.
Wire the normally closed path, into the original board, so that you have forward - running lights.
Use the reverse-light feed from the Revolution to switch the relay. - This swaps the polarity of the power to the original board, so changing the directional lighting.
I'll draw up a diagram..Hi Philip can you expand a bit on your advice for me please
Paul d
Brilliant thankyou,by the way do you know anyone selling revo receivers pleaseI'll draw up a diagram..
Which ones?Brilliant thankyou,by the way do you know anyone selling revo receivers please
Yes the 2.4 ghz receivers preferably with steam soundWhich ones?
I assume the older 'new' 2.4Ghz ones?
There are also very old one's, and (I think) a really new version..![]()
GRS might still have some?Yes the 2.4 ghz receivers preferably with steam sound
Grsuk dosent think he has any unfortunatelyGRS might still have some?
Matthew bought - up all he could get..
Hi Philip I got on to grsuk,uk ,he had to get back to me.Did you manage to.get time to draw me a diagram by any chanceGrsuk dosent think he has any unfortunately
P paul delany , did this materialise? and if so, were you able to solve the lighting issue?I'll draw up a diagram..
Hi hello there no not yet unfortunatelyP paul delany , did this materialise? and if so, were you able to solve the lighting issue?
Hi tony I'm wanting to fit a revolution sound decoder into my k-27 ,greg mentioned you used to make an optoisolatir board the interface between a sierra sound pcb and the motor control voltage in order make the sierra pcb detect change in speed etc ?do you still have the parts to make one please.Hello Phil.
That is exactly how I recommend all USAT locos.
Don't forget the snubbing diode across the relay coil.
