A query in two parts; last year my attempts to run a G scale train around the tree were just but only just acceptable.
To begin with I have limited space available ie a diameter of only 31"(80cm) to the track centreline. I tried bending Accucraft and LGB flexitrack but the joints were decidedly "clunky". I even bought a rail bender s/h (GRS?) but that proved not to be of any use whatsoever, to begin with the profile of the rollers despite being claimed to be "LGB", did not match LGB or Accucraft, or Aristo or even Peco. Even if the profile had been correct I couldn't see how the rail would feed into the bender as the rollers are all smooth and the moment pressure is applied to put in a curve the rail simply slips on the rollers and does not feed.
Consequently this year I have resurrected my OO and N gauge equipment after a long "rest" of well over 20yrs.
Everything seems to run Ok but I don't relish the constant track and wheel cleaning. On digging out my Relco unit I realised that in the absence of the instructions I haven't the faintest recollection of how to connect it other than recalling that it wasn't just a simple "connect the controller leads to one side and the track ones to the other. For reasons which entirely escape me I had left it with one of the Controller Side terminals hard wired to the Track Side one
Can anyone assist please in an idiots guide to setting it up? Or even a scan of a set of instructions.
The unit is an early one marked TypeC.
One other solution would be preferred - is there any track out there with a radius of 31"?
