Cliff George
Hello Mick,
Thanks
To start with yes, but I've allowed access to the central shaft from below for possible use of the PTC III system:
http://www.nyrs.com/default
or maybe something of my own invention.
Yes, got that covered too. Power for one side of the track comes through the central shaft, for the other side through the taper roller bearing. I've been careful to keep these two isolated from each other. If something doesn't quite work with this plan (and I don't see why it shouldn't), plan B would be to use one of the first two methods and the (I'm not quite sure what they are really called) outriggers.
			trammayo said:Some great work there Cliff
Thanks
trammayo said:is the turntable going to be manual
trammayo said:and, how are you intending to maintain the power supply to the track
