This post should pretty much complete the works.
Job 3 Rehash Piping Left and Right Hand Side Completed
The final part here was the Pipe from the Front of the Tank that overhangs the Bogie. This was a Thicker Piece of Copper, flattened at one end to assist Supergluing to the Tank. The end had a small length of 2.6mm Heat shrink added to allow Movement should it get caught on the bogie. The next pic shows this and a similar Pipe on the Right Hand Side.
The right hand side was a similar job of bending and placing Pipes. Some have been `Planted` into existing holes, a couple of additional holes have been added to the Cab to assist with Pipework Placement. The existing High Pipework that so dominates the original Model from the Cab has been reduced to just one. I also removed the Tank (just in front of the Cab) as there is a Smaller One locate on the Cab, another Job! The remaining holes have been plated over with Black Plasticard as were some on the other side, some Cosmetic Rivets were made with a Scriber.
Job 11 Box with Pipes on Left Side of Cab Completed.
This was the inevitable piece of Copper Wire soldered into a Small Box made from 2mm Square Brass. Whilst Soldering this in, sufficient Solder is added to ensure that the ends are Blocked. Thus when cleaned up it looks like a Small Box.
Job 16 Driving Crew Completed
These were modified so that the Fireman has a Shovel. The Driver has a New Head courtesy of some leftovers from a Piko Kit. A Shovel was placed in the Fireman`s Hand. Both had holes drilled into their feet, a Pin was pushed into these so that they could be planted into a Small Hole in the Cab Floor. A dab of Superglue and they are on 24/7/365 Day Shifts. The Driver has his hand on a Regulator, superglued onto the Firebox. Made from Flattened Copper Wire.
Job 18 New Job Rear Lighting Pipes Completed
These were made up with Copper Wire and more Boxes made from Square Copper Tube as described in Job 11. A Small Nail was soldered to the Back of the Squares so that they can be Glued into holes in the Cab. Placing these takes a bit of patience to get right. The Pic shows the Placing. This pic shows this and the Pipes from Job 8.
Job 19 New Job Tool Box on Right Hand Side Completed
The Tool Box removed from the Left Hand Side is placed on the Right Hand Side, a New Hole was drilled so that it can be placed with the Original Screw. A couple of small slithers of Plasticard represent the Hinges and Padlock Strap.
Job 20 was the new Taps Completed
Job 21 New Tank for Cab Rood Completed.
This was made up with some Brass Tube that I had to hand, somewhat smaller in diameter that the Original Tank, it needed to be which is why the original was not used. I Soldered some Brass onto one end, drilled the end for a Pipe Run. Most important this as it also is needed to vent Air when soldering Brass on for the other end. Cleaned up the end pieces by chopping the excess brass off and dressing in the lathe. This could be done using an Electric Drill held in a Vise. More Brass made a Frame which was then Fused into the Cab by Gentle Heat applied with the Soldering Iron to make a couple of Groves so that it could be Sited on the Roof. The pipe runs go through a Couple of Holes in the Roof and when bent over underneath secure the Tank in Place.
Job 6 Weathering most done for now.
I have done most of the Weathering now, but feel that a bit more perhaps Black Sprayed is needed below to loose the Bright Red of the Frame and Wheels.
Job 5 Additional Lettering on Tank.
This remains unresolved till I can work out exactly what it is. I have not yet found a Picture.
Here finally are some Pictures of the Loco out on the Line with the Black one for comparison. All that remains is for me to do a Short Vid of her running and some pics with the Painting Completed.
So there we are, £1200 quids worth of Loco totally taken out of its warranty. But I like it.
