track wanted
Choppercook
I want to replace all my old Peco plastic track with good brass track , I need to replace 69ft of straights , 53ft of bends and 6 sets of points, , any suggestions where I can get them from ? new or second hand
Quite a lot of track needed there.
What Radii are your bends?
Second hand R1 curves are cheap enough on Ebay and second hand and they can be straightened if required? Expect to pay £3-4 a foot.
Again what points are you wanting?
I guess LGB R3 points are close to Peco ones....
I have 6 LGB Radius 3 Right Hand points @£25 each as well as 7 LGB R1 points - 6 Right 1 Left @£20 each for sale as well as an LGB Double Slip @ £50. I also have 6 LGB R1 curves @ £2.50 each. All the track is used and the points do not have motors.
Regards
Martin
I have the Peco plastic track, after 2 years out in the garden it bracks and is useless
I don't think it is Peco track? - Not even Piko.
I think it is the plastic track supplied by East Coast Railway, which is the Nequida / Train brand, so it will be equivalent to LGB R1 curves and points.
yes that wear I got my first loco and track from , they have NEW PIKO G SCALE 45mm GAUGE BRASS METAL TRAIN TRACK COMPATIBLE LGB BACHMANN, not bad prise , what you think would it be OK
As I mentioned above I have LGB R1 points and 6 R1 curves
I have an unknown number of LGB 30cm straights surplus to requirement you can have. I'll try and sort out what I've got this coming weekend,
I have something like a dozen so far. Some need connectors, but this may not be so important with battery power as the rails will be held in place by the track either end. I have R curves surplus too.
I have some LGB R1 curves and short stapraights, send me message via the forum if you are interested and will sort out to do a deal.
Oh and Peco do not do plastic railed track. Lest anyone should think Peco is inappropriate in the garden I have had Peco yard lengths and points in my 3 garden railways continuously outside since 1988 or so.
