Anglian
Hi all.
In the next part of the, 'Idiot's Guide to the Garden Railway', comes the question of voltage drop. I will be connecting the MTS III and transformer through the wall for track power and separately analogue-powered points.
I only have to have a run of 5 metres for each. The points are no problem as they will only require lighter wire but my question relates to providing track power. I have read that heavier cable is advised and so I plan to use an old strimmer cable which is too thick to attach directly to the MTS III. I intend to run thin cable through the wall and then attach the two using a waterproof junction box the other side of the wall. This will mean a narrower hole through the utility room wall which keeps important people happy.
Is this fair enough?
Trevor
Trevor
