I have been doing some research on what is the best type of battery to use in my next set of large diesels locos to be converted to have the option of being winter battery runners.
My locos also have to climb a very steep incline so will be drawing a pretty high amperage when dragging a train up the slope. So the added weight of a trailing battery car is not best solution.
As I want to fit the cell-packs into the hoods of diesels I concentrated on comparing AA sized cell-packs to deliver 19.2V (16 cells) at about 2600mAH (real life delivery power). These conclusions would also go for 14.4V packs (12 cells).
I have spoken with a few hobby battery retailers including the excellent 'Component-Shop.co.uk'.
This is what I have been told by the guys who know a bit.
NO AA sized nimH cell can deliver what Chinese importers are claiming 3000 -3600mAH)...some even go as far as claiming 4000mAH. This is just hype and hot air.
NiCad...
Good and strong with good amp delivery but can have memory effect if not treated properly. Holds its charge fairly well
NiMh non-LSD..
Better than Nicad for putting up with charging abuse but..self-discharges quicker and can have problems delivering continual high amp output such as that needed by USAT /ARISTO dual power block locos under load.This can lead to shorter running times
Is best for low amp power blocks like those in LGB locos or some other manufacturers where a 14.4V pack can give a good couple of hours running.
SUB-C size cells give better performance as they have larger charge capability
NimH LSD (low self discharge)
Holds charge very well but has problems delivering high amp output for continual use (even worse than non-LSD NimH type).
They do need a long time to recharge if they have been drained (could be up to 32 hours!) and cannot be fast charged.
Again SUB C cell size would be better
Lithium chemistry
When I asked about Li-ion, Li-Po and Li Fe I got some interesting replies, especially from retailers who specialise in Aero and car racing applications (including Component-Shop)
All LI chemistry batteries are capable of fast discharge at high amps but also able to give continual delivery of our G scale 'normal' amp consumption.
They are light in weight and smaller than comparable power NimH/NiCad
But they do need protection during charging and discharging
Nearly all of the Li-packs advertised for hobby use are supplied to the aero.racing fraternity and do not have protection circuits to prevent over charging or discharging.
Li-ion...
There has been a very good thread on this forum about Li-ion by Peter (whatlep) http://www.gscalecentral.net/Lithiu...ata-on-shelflife-and-discharge-rates-m165095. < Link To http://www.forum.gscalece...ge-rates-m165095. This examines some batteries from ebay which DO have protection circuitry
I have a couple of Aristocraft 22V LI-Ion packs that just have the two wires for charging and for discharging as they have the built in protection circuitry. I would like to have more of thebut they are not cheap
Li-Po...
Even lighter than Li-Ion with even more power handling But......
If a Li-Po battery is allowed to drop below 3v and then charged it is then that there could be definite possibilities of fire.
For G scale purposes where the battery may be inside the loco or inside a trailing car, there needs to be some definite way of protecting the battery as even an audible alarm for over discharge might get missed.
Lead acid
Strong, very resilient unless totally discharged, good power delivery. But very heavy and to deliver 14 tp 18 v the size would just be too large.
My conclusions for what I might use are.....
For NimH
SUb-C cell NimH packs (possibly LSD type) would be ideal if there was room inside the loco (a good long hooded diesel). Remember I am really thinking here of USAT/ARISTO large diesel motor blocks. LGB ones would be quite happy with the lower mAH AA size celled packs.
For Li-Ion
Not so volitile as Li-po. A little more forgiving but still has to be treated right with protection circuitry. As I already have a couple then it makes sense.
It will be excellent to hear other member's views and experiences.
If you have views totally at odds with this, it would be great if you gave reasons as I am open to change me mind.
Remember I am talking about USAT/ARISTO dual bogie locos with higher current usage, as opposed to locos with lower voltage and current needs that would be totally fine with 12v to 14.4v AA packs.
NiCad...
NiMh non-LSD..
Lithium chemistry
Li-ion...
Li-Po...
Lead acid
For NimH
For Li-Ion
