Bluetooth Wireless DCC anybody?
With the recent demise of the CREST Revolution. I was left with the dilemna of how to control my own high-power and external sound cards for large scale locomotives. - That is, in G, G3 and 5" scales which are currently controlled using extensive hardware integration with the CREST Revolution controller and it's associated receivers.
Having to rebuild and integrate everything with a new supplier is something I am not looking forward to.
Historically: Four or five years ago Navin and Lewis were advised to put a DCC output on the Revolution receiver so that the likes of ZIMO, LOKSOUND, etc could be used to provide onboard sound and if required - locomotive control until they were up and running with their own sound system architecture.
Well, I got shot to pieces with that idea - particularly from Luddites on the Aristo-Craft forum, (Who erroneously thought they had to build a whole DCC track network). The receiver 'would have been' and 'now is' the DCC network! Thus making cabling up a DCC track power system utterly redundant - just as it has now done so in reality.
After searching recently and ready to give up. A chance conversation with a fellow G3 designer stated that a 'Bluetooth Wireless DCC' system is now available which allows your favoured Aristo-Craft locomotives (and others) to be run under battery power.
This is Tom White's wireless specification for his G scale Aristo-Craft Dash-9 install.
Bluetooth Controlled Dash 9 update:
The system requires a DCC base station to which is attached a Bluetooth wireless transmitter, communicating with a Bluetooth wireless receiver with power output to the locomotives motor, Alternatively an external DCC Sound Decoder can be plugged into the Bluetooth Receivers DCC output socket.
Thus all the favoured sound systems from the likes of Soundtrax, Loksound, Zimo etc cab be used with your favoured sound program editors files. I.e. Legobiffoman, Paul Chetter, Howes Models etc. Thus, sounds such as these are possible:-
Ahem. Just remind me of what the CREST Revolution sound system did?
Well, the Bluetooth loco controller can be standard DCC controllers from the major DCC manufacturers or nice colourful Apps which reside on your tablet or Smartphone.
All the Bluetooth and DCC components replace the CREST Revolution equipment in its entirety. Admittedly, a commercial DCC Base Station is not cheap financially, neither are commercially programmed DCC Sound Cards, but the rest of the kit is as cheap as chips. Plus with the enormous range of sounds from all the commercial DCC sound suppliers . . . Decoders from Soundtrax cover most bases with US centric locomotives, whilst UK programmers cover many UK prototypes and the major European DCC decoder manufacturers cover many, many more US Centric and European Steam, Electric and Diesel prototypes.
CREST Revolution: "The King is dead, long live the King" - Although the Crown is due to be passed on anytime now.
Oh, if this was of any interest just do a websearch for the Dead Rail Society
- - Form factor similar to the Crest Revolution
- - 200ft+ range
- - Now supports 12amps continuous draw with peaks of up to 30 amps.
- - Can now report motor amperage draw in real time
- - Can theoretically read back voltage level as well
- - Auxiliary motor voltage output to feed into a sound system for chuff chuff or pulsed smoke system.
- - Cost as DIY: ~$35
- - Cost ea @ 100: ~$20
- Battery box switch on/off
- Cab Doors opening and closing
- AWS and Fire Alarm test bells
- Control Desk initialisation sirens
- Oil pump primer sequences
- Multiple Engine start sequences (cold and warm)
- Dynamic Engine Running sounds matched to the power lever position
- Engine shutdown sequence
- Air tank popping (water release)
- Variety of Air Horns
- Pantograph raise & lower
- Transformer Hum
- Traction Motor Whine
- Synchronised Cylinder Beats
- Boiler STeam Raising
- Boiler Blow Off Valves
- Coal Shovelling
