tramcar trev
That looks nice? But what is it??
Its called in tramway circles a GCG, groove cutting guide/gizmo/gadget? when its seen screwed to the base of a Dremel router its use becomes obvious, doesn?t it? In use it?s guided along the inside edge of the rail on the 2 brass pins and the carbide cutter cuts away the material forming the groove for the wheel flange to run in. Being a carbide cutter it will be used to form the groove when the space between and around the rails is macadamised or paved or whatever granite setts always look nice?
