Inclines....oh those inclines.
I have a garden that unfortunately rises up away from the house so had the option of either a very long tunnel or a long cutting OR making the layout go up the incline. Because of the troubles with very long tunnels and cuttings and the fact that the train would not be seen for a long time I chose the latter.
Over about 25 to 30 ft it climbs about 3 ft which is about 12% overall, although it does vary and is higher on one place.
All I can say is make it as gradual as you can as any sudden change in gradient will put strain on the motive power and either cause a noticeable slowdown or even can cause uncoupling (if you use certain brands of knuckles).
Also what goes up, must come down and if there is any sudden 'kink' surprises for when a loco(s) and all the weight of the rolling-stock behind, you will probably have problems.
I had the actual land to give me the track angling process but I did make sure that there were no 'kinks' during and at either end of the inclines.
Of course a rack railway is the answer if running short trains
This shows the incline at about 10%
My signature pic below shows steam locos battling the incline
