ge_rik
Just thought you might be interested in progress on my first semi-scratchbuild of a steam loco - the Southwold Railway No. 4 - Wenhaston.
The bodywork is almost complete - needs another rub-down and some cosmetic filling here and there before the top-coat goes on. There's still a fair bit of work to do under the footplate and the electrics need to be installed. She's going to be my first fully-fledged battery powered loco.
The donor for the chassis was a Zillertal U-class.
The wheel sizes were spot on for 15mm scale - though the wheel spacings are out on the trailing drivers. I had hoped there would be plenty of room inside for the batteries etc, but as it turns out I've had to make a few compromises to fit everything in. I've managed to keep the cab clear so there is some backhead detail (courtesy GRS).
The dome was my biggest problem. GRS supplied me with one for a Gauge 3 Jinty which was the right size but had a flat top. In the end, Mr. Sainsbury supplied one - from the top of a sun cream bottle - thanks to the spell of good weather!
The dome is very slightly over-size (would have been perfect in 16mm scale!).
Hope to finish her off over the coming week. I could really do with some bad weather to have an excuse to work inside!
Rik
Rik
