Joecaboose
How can I improve the slow speed performance on my Roundhouse Forney?
How long have you had it, if it isn't run in that will affect the ability to control it.How can I improve the slow speed performance on my Roundhouse Forney?
SloMo is what you need, but not sure if you can get one for that loco. Have a look or chat to the owner of this site.How can I improve the slow speed performance on my Roundhouse Forney?
Unbeatable? I disagree.Noting what Tony and Casey said and I do respect their views, for true slow speed and shunting the SloMo is unbeatable IMHO.
Interesting, why do you disagree.Unbeatable? I disagree.
Tony, honestly, some very interesting points, which I cannot disagree with (mainly because I do not have Slomo), but you last line (it is true to say that they make a major change to a loco's performance characteristics.) almost seems to argue for their virtues.Almost the same result can be achieved by good loco management, i.e. running at a pressure well below whatever the safety valve is set to blow. Much cheaper, and achievable without modifying the loco. Slomos are certainly clever and well-made, if a tad noisy for my personal liking. Are they unbeatable? Certainly not. I've installed several, and it is true to say that they make a major change to a loco's performance characteristics.
Well we must agree to disagree. i have no issue with that.Almost the same result can be achieved by good loco management, i.e. running at a pressure well below whatever the safety valve is set to blow. Much cheaper, and achievable without modifying the loco. Slomos are certainly clever and well-made, if a tad noisy for my personal liking. Are they unbeatable? Certainly not. I've installed several, and it is true to say that they make a major change to a loco's performance characteristics.
Characteristics can be good, or bad.Tony, honestly, some very interesting points, which I cannot disagree with (mainly because I do not have Slomo), but you last line almost seems (to) argue for their virtues.![]()
Agree Tac, I have 2 Roundhouse locs fitted the others are geared drive so slomo not required.Unless you are prepared to install a Slo-mo device in each loco - something that might be painful to your pocket but will surely please the makers - the other option, taken up by some - is to install it in a wagon of some kind that will always be part of the consist.
Or, as Mr Rhos Helyg notes, effect more control over your locomotive by turning down the gas.
For improving the performance do you mean it will not run slowly or does not have much power at slow throttle settings? My Roundhouse Forney has always been a good slow speed performer, excellent for shunting. Fitting a SLOMO is academic in this case, as the Forney has inboard eccentrics and valvegear, between the frames. Turning the gas down and run at 20-25psi would be worth a try. Also see if the valve events are okay. Roundhouse have some instructions on their website at Forney Valve Gear My Forney did require new o-rings on the pistons a while ago, the originals having become hard and worn. Your piston o-rings may have gone hard with time as 10 hours usage is fairly low.How can I improve the slow speed performance on my Roundhouse Forney?
Ah there is the rub, inside gear is the killer to any slomo conversion. Not had a look below a Forney so not aware of that as an issue. Some time back I was twitching on buying a Roundhouse Garratt, a SloMo for me was a must but when I looked below it would have been impossible to fit a SloMo due to the run of the main steam pipe. Hence I do not nor ever will have a Roundhouse Garratt.For improving the performance do you mean it will not run slowly or does not have much power at slow throttle settings? My Roundhouse Forney has always been a good slow speed performer, excellent for shunting. Fitting a SLOMO is academic in this case, as the Forney has inboard eccentrics and valvegear, between the frames. Turning the gas down and run at 20-25psi would be worth a try. Also see if the valve events are okay. Roundhouse have some instructions on their website at Forney Valve Gear My Forney did require new o-rings on the pistons a while ago, the originals having become hard and worn. Your piston o-rings may have gone hard with time as 10 hours usage is fairly low.
Have not done precise calculations but I have a short section of 1:25 grade on a 4ft radius curve and the pulling power of my Roundhouse Jack and Ted is much the same on the section before and after SloMo fitting.My understanding of the principal of a Slo-Mo is that it uses an overdriven flywheel to smooth out the power delivery. But given that nothing is for free in this universe, doesn't the energy required to activate the device have an adverse effect on the available drawbar pull - and wouldn't exactly the same end result be achieved by simply loading up the loco with more rolling stock, rather than driving a flywheel with its associated gear train and bearing friction?
BTW - has anyone done a spring balance drawbar pull comparison - both with and without the device - all other conditions being equal?
