collectors
Yes, correct. Rather than one track with a single loop i will get two tracks with 2 return loops. Should give a little more traffic room. "With some care"So anything travelling down the L/H track returns to the L/H, and the same for the R/H track, before travelling down one track, returned via the other track, but no more, is that what you want.
There's a metaphor lol. But, I'm waiting for it to warm up a bit as my 2"pipe is a little stiff in this cooler weather. But the 2" pipe came in a coil that was in-between an R3 & R5 bend, so this has helped. I do have some R1 turn offs, but only in siding & stations so dont need the tube. But at worst i will gently treat it to my blow torch.Looks really interesting..
How stiff is your pipe?
Can't wait to see something battery remote controlled buzzing round!
It'll be interesting to find out how the sun affects themThis does look pretty bomb-proof (barring Vlad the Invader).
I will be interested in how it fairs if we eventually get some hot weather?
I am thinking of trying some of these, inverted, possible sitting on a thermalite block?
Loft Storage Stilts - Box of 96 (11.3m² Space)
Most Popular Quantity Sold Create 11.3m² of storage space. FREE TRACKED NEXT DAY DELIVERY IN THE UK and IRELAND Will create a raised boarded area above the government recommended 270mm Insulate your loft AND keep your storage space. Create a raised platform to insure the insulation is not...www.loftstilts.co.uk
They certainly look cost look cost effective. Might be worth dropping them a line as i believe its an additive they put in the plastic to make it UV protected & might not be needed in lofts. But always nice to see alternatives & thinking of different ideas to steer our thinking down other paths. What is it they say? Necessity is the mother of invention.It'll be interesting to find out how the sun affects them
The biggest problem in the UK, is timber in the garden..There are always possibilities... you could double stack those thingies, but I'm guessing that overall they would not be cost effective...
I've used some of those under my deck, the seem to work fine, but my not be high enoughJust an alternative. LINK
