I'm currently attempting to construct a battery powered loco for the first time. My plan is to use the Piko rc system (35040) with mylocosound and a li-on battery used for cctv cameras. Because I'm not very good with electronics I want to keep it as simple as possible. My plan is to wire it up like in the attached diagram but instead of sending the wires from Piko rc to the battery/ switch/ charge socket / fuse arrangement, the wires from V1+ and V2 will go directly into this battery using the same type of socket that is used for the charger (Safari Drives 12V DC 30W 81.6Wh 6800mah Rechargeable Lithium Ion, Li-ion Portable Battery Pack, Power Bank for CCTV Cameras, LED Strips and more. With UK Plug Charger: Amazon.co.uk: Electronics & Photo). This way in order to charge the battery all I would need to do is unplug the battery from the loco and charge it with the supplied charger. Sorry if this has not been explained too clearly. Are there any reasons that this set up would not work?
Thanks,
Harry
Thanks,
Harry
