So ask Accucraft for a list of current suppliers / repair agents..Searching for Servo Mounting Brackets for an Accucraft Ruby, only locating sellers from years ago that have since closed shop.
I made servo brackets quite easily using L apsheps aluminum strip for my 00 point operating ones. A bit of work with a junior hacksaw, drill and file should be a relatively simple lead into learning some metal work.It shouldn't be too difficult to fabricate one from a bit of metal. I would suggest get in touch with the 16mm Association, bug I'm not sure if that would be much use to you over there
