ge_rik
Following-on from GregH`s thread about semaphore signal bounce, I have now been able to apply his excellent Picaxe program to controlling the first four of my semaphore signals. Sorry about the video, it is mildly more interesting than watching paint dry, but it is only a minute and a half long.......
[youtube]http://www.youtube.com/watch?v=D32Wacc-kg0[/youtube]
For those with an interest in things technical. The servo is mounted below the signal and connects with the balance arm though a bell crank (this will be painted black)
The servos are then connected to the output from a Picaxe 14M2 Project board. It`s not essential to have the board but as I was experimenting I thought it would be handy
The Picaxe chip is energised by four outputs from one of those cheap receivers. This is a slightly more sophisticated version which can be modified to provide momentary, latched or self cancelling outputs on the relays. I`ve got another four on order which provide only momentary outputs but which are half the price. I wanted the more expensive version initially so I could play around with the different types of output. Many thanks to whomsoever on here who alerted us to these wonderful little gadgets.
And here`s the transmitter. Four channels which is perfect as each of my stations has four signals (two starters and two homes) - so one keyfob per station.
Still got a way to go - providing a power supply for each station (which will also light the LEDs in the lamps) - and figuring out how to site the signals with the servos in pits beneath which will somehow not get filled with rainwater - a bridge I`ll cross when I reach it - ho ho.
Thanks again to GregH for his Picaxe program and his help with sorting out the electronics. His program is far more realistic than some of my signals suggest - I`ve still got some tweaking to do on the linkages to show the programming off to best advantage.
Rik
Rik
