Saxon Meyer valve gear
Dinas Bryn
13 Mar 2010
6,691
16
Hi I appear to have bent the rod going into the cyclinder. a is the plastic gear a push fit? b as it is plastic can I straight it in warm water? or is there another way Les
stevedenver
255
i dont have an SM
but
i would try and remove the assembly if possible-
then ever so gently
see if you can gently bend it with fingers-
if you determine it to be plastic
i would try warm water, not hot to start
i might let it relax, ever so slowly, back toward its original shape
i would be wary of either brittle plastic or metal-which could break altogether
sorry to hear this
the hopeful part is that if it slipped out during a run -hopefully it wasnt jammed too hard
stevelewis
39
Buckley NR MOLD NORTH WALES
LES
It should be pretty easy too straighten the piston rod it is plastic and should easily be straightened with the aid of a little hot water!,
As far as I can remember the piston rod just enters the cylinder and thats it!!
Dinas Bryn
13 Mar 2010
6,691
16
Morning Steve thats what it does, I will leave Kieth to have a go after he has finished the the Eist thank you all for your help Les
stevelewis
39
Hi Les
On my first Saxon some years back when they first came out one of the valve gear rods broke!!
It was my fault, a big stone had rolled near the track which I did not see and the loco managed to jam itself as it went by it!
At the time they could not supply spares so I used araldite to repair it and it worked very well, went on to do quite a bit of running.
Trainman
All narrow gauge and industrial railways,
459
Auckland
Same happened to a mate of mine. His valve gear hit some worm mounds and snapped the rigging. He ended up making new ones from brass. Still working ok. One happened then another later. LBG couldn't help with spares either. Good luck- maybe Model Land in Germany can help if things do go pear shaped:crying:. Just helps to have a back up sometimes. Good luck.
Dinas Bryn
13 Mar 2010
6,691
16
Hi Steve as you know my track goes into the petrified forest, gods knows what is in there Les
