casey jones snr
		Oooh - poles apartThe biggest single difference between different electric motors is how well they are made.
Once you get to a quality motor with good bearings, lots of wire in the windings, balance, magnets etc. a three pole motor will usually run faster than a multi pole motor - because there are less electrical changes in the armature. It may however start and run less smoothly.
A multi pole motor has to have smaller windings on each pole - otherwise the motor would need to grow in size considerably - this tends to limit the torque to about the same whatever the number of poles.
Power is torque x speed. Torque remains fairly consistant and a three pole motor can run faster - more power.
On to all this you add gears and drive wheels - all of which can make a huge difference to the overall performance. As a three pole motor may be running faster, it needs lower gearing for our use - which increases power - again.
But, at the end of the day, quality will out perform poles.
		Roundhouse "Deep Brunswick Green".Oh yes. Loving that green one.
		.............and yet some of their chassis use Buhler 5-pole motors
		Yeah, well, that's what started me off - I usually go for a 5-pole motorMulti pole motors tend to start and run better. We often run our motors quite slowly - a multi pole motor is probably smoother.
 - although I do have one loco with a Buhler 7-pole motor, but with its 50:1 gearing, it's difficult to really pick up how smooth it is
		I like the look, but those chains look remarkably close to the railhead?
I hope they don't catch on anything..
		This is in the battery powered section..
		Sensible conversion Paul, double buffers unless they are oversize will not work that well through many of your points as you have found out. I would think R3 minimum and then not on a crossover but to a Siding that has a good straight length before any curve. On my 0 Gauge Standard Gauge Light Railway I had to incorporate a bit of straight on the 2’6” Crossovers and with the Bogie Coach have Elongated oblong buffers to stop locking.Due to operational difficulties (buffer lock when shunting) I decided to change the outside buffers and coupling hooks. I wasn’t overly keen on the single combined coupler and hook. I opted for the multiple height coupler which I think suits the locomotives rather well. The side safety chins also serve to disguise the original side buffer holes.
View attachment 248676View attachment 248677View attachment 248678View attachment 248676View attachment 248677View attachment 248678
		Optical illusion Phil, they don’t extend below the buffer beam.I like the look, but those chains look remarkably close to the railhead?
