Greg Elmassian
Guest
Phil, is your post for a 55021 or a Massoth. Some valuable information here, would like to archive it.
Greg,Phil, is your post for a 55021 or a Massoth. Some valuable information here, would like to archive it.
Ok, that totally explains the Massoth not working. Is it possible to update the firmware?CV 7 = 155, CV 8 = 123, CV 255 = 130
Firmware version 1.5 is dated from 02.07.08
Serial Pulse Mode was not introduced until Firmware version 2.4 dated 20.12.10
Sorry, but I don't understand what you're getting at here. Setting CV51 to 9..16 causes the F1 output to be driven normally by one of F1 to F8. Have tested it, it works, but not what I'm wanting.CV 7=28 CV8=123 CV 106=192
Looking at the LGB 55021 interface, I found the serial / parallel mode setting.
On the 55021, CV 51=1 (default) enables a mode where F1-F8 trigger the "F1" output that many times.
Tested with both PIKO and Massoth systems, does exactly what it says on the tin.
LGB 55021
CV 51
= 9 F1 Key serial
10 F2
11 F3
12 F4
13 F5
14 F6
15 F7
= 16 F8 Key serial
That's an easy one to answer.HI Andrew, I'm confused why you are so keen on retaining MTS 1/early MTS 2 era serial operation. Is it just to operate a couple of outdated loco decoders? If so, seems kind of silly to me. Just replace them. Decoders are not that expensive. If it's for the learning experience, then it kind of makes sense. But it's an early, long outdated, digital system in any case. Just curious.
Ah, that makes more sense to me now.Like you mention, the "Fast Pulse String" provided by the decoder is too fast for the Sound board to process. This cannot be slowed and it was why Massoth originally provided "P Updates" to locos with sound boards that I mentioned back in post 15.
HI again Andrew,That's an easy one to answer.
