Well, as I finish up the FO/MGB Tm 2/2, it’s time to start the next build! (Actually, the “next build” started last weekend!)
So the next item on the docket, a small model of the RhB’s “Schienenschleifwagen” - their towed, non powered Rail Grinder. Very little about the prototype exists. Nevertheless, master modeler (and forum member) Torgrim produced a fabulous 3D printed kit for the model. You can find it here: RhB Schienenschleifwagen by TLoco on Shapeways
What’s really clever is that the model is designed to house the standard LGB “Track Cleaner” unit - so while the prototype reprofiles the railhead, this model cleans it! As soon as it was offered for sale, I purchased a kit - then promptly lost it in the impending house move. It finally turned up while working this spring on the Tm 2/2 and so I sat it aside to start next.
This past weekend I started to look for reference on the prototype. Sadly, no much exists!
Schweers + Wall have only one small bit, that offers these photos:
After hours of hunting through german rail photo sites, I turned up this shot from 2016:
Interestingly the above photo shows the unit in a road trailer, rather than on a rail wagon. Schweers + Wall indicated that the unit was more or less assigned to a Xe 2/2, but this leads me to believe it may be more of a “as needed, where needed” piece of equipment.
My thoughts then tuned to other modelers’ builds. Frustratingly, it appears Torgrim himself was the only person to attempt building this model - and he apparently stopped somewhere before finishing / detailing.
So, with only the above to guide my build, this is going to be a bit tough. I did go have a dig for other meter gauge Swiss Schienenschleif unit photos on the internet.
I turned up these two - which appears to be a similar, small non-powered “tow” unit. I’ll base some of the under carriage on what I can make out here:
So, here we go… time to build!
- 3
- 2
- 1
- Show all
