That's a good idea Mike!dutchelm said:If double isolating joiners were inserted into both legs of the first point out from the station, the station section could be switched to change the polarity. This could be done automatically using a changeover switch operated by the point (as supplied as an extra by LGB or others).
Sorry I cannot manage a drawing.
I would agree leave the shed part so that polarity can be changed isolate both sides of the point. put in a reed switch on the curve on the left to a double pole double throw the reverse the poarity in the isolated shed section.Gizzy said:That's a good idea Mike!dutchelm said:If double isolating joiners were inserted into both legs of the first point out from the station, the station section could be switched to change the polarity. This could be done automatically using a changeover switch operated by the point (as supplied as an extra by LGB or others).
If the point is motored then the polarity could be changed using a LGB 'type 2' switch attached to it.
I have amended the earlier diagram in yellow, and I can help with wiring the switch if Tel wants to use your idea....
Hullo Tel,tel said:many thanks for all your help,i have just had a thought,if useing the lgb reverse loop set the train has to stop to change direction could this be done like my new drawing,stopping the train actualy in the station,would i have to isolate the outside track![]()
By polarity switch, I think most are refering to the LGB 12070 Type 2 switch that mounts onto the side of the point motor;tel said:thanks again for your help,i like the idea of a polarity switch from mike,and i would be very grateful if gizzy could help with the wireing,where do i get a polarity switch,and what do they look like,i asume when the switch is connected to the manual points it makes it fully autmatic, Tel(JakeTelRailway)
