I use a Massoth 1200z and all locos are chipped, so therefore lights are 5V
thanks
Thanks for all the helpful replies, I guess I just order LEDs from Maplin or similar.
I have never seen an LGB engine that outputed 5 volts to lights or smoke unit!!!!
I usually see 6.2 to 6.8 volts on these.
When calculating resistors for leds I take an easier approach as follows:"
For 10ma leds, you need 100 ohms per volt dropped. So a 3 volt led on a 12 volt supply needs 9 times 100 ohms for 900 ohms and the resistor would be 910 ohms.
For 20ma leds you need 50 ohms per volt dropped. (or use a CL2N).
