Replacements for yellow isolating track joiners.
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
Has anyone come with a homemade idea on track joiners that would isolate a track section other than those yellow ones from LGB? Thanks Mike
Rhinochugger
Retired Oik
4,234
North West Norfolk
I think Accucraft are black ;);)
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
Thanks for your replies, I was hoping for some homemade ideas.
LVT
Analogue automated LGB Euro on 4 loops
10
Near Atlantic City NJ USA
Small plastic I beams in parallel glued to a flat base can do it, but strictly “light duty”.
4,976
Or perhaps a take of Massoth with a 30/40 thou Plasticard created one with a digit to stop Rails joining and nuts n bolts to hold to rail. Not the best of sketches but I think you should get the concept. Sort of like a Massoth Isolating Track Clamp.
korm kormsen
289
Paraguay
afterthought:
you could get somebody with a 3D printer, to make some for you. the printfile is for free on thingyverse.
as this forum does not accept my pics, here a link for opening: http://kormsen.info/specials/bilder/3d07.JPG
(i prefer the first method. the material is and stays elastic. the 3D printed joiners might break under stress)
D
Deleted member 4232
Guest
Moved
phils2um
Phil S
11 Sep 2015
1,522
423
Ann Arbor, Michigan
United-States
I would just go with the Massoth ones. They're strong, not that expensive at around $6.50 a pair or $30 for 5 pair and very effective at keeping the rails together. Plus they come with tabs if you want to attach wires to the rails. This is one of those things I wont try to hobble - it's just not worth the effort.
Phil S.
playmofire
23 Oct 2010
8,249
853
80
North Yorks
What is the problem with the yellow LGB ones? The colour? On new/newish track it probably won't show up all that much. On older track, does it matter?
maxi-model
661
Bucks/Oxon/Northants area
The expression, "spoiling the ship for a ha'penny worth of tar", comes to mind :D Think of how much you have invested in the infrastructure and rolling stock for your line and then look at the cost for track insulators as proportion of that. Bit of a no brainer unless creating every element from scratch is your thing. Sorry if I'm making an assumption but I can see no other reason for insisting on "home made" other than as mentioned or lack of availability/ability to source said items for some reason :) Max
Zerogee
Clencher's Bogleman
1,723
North Essex
I would concur on using the Massoth ones - black plastic (nylon?), hence much less visually obtrusive than the yellow LGB ones, and a good solid screw fitment as opposed to the very loose fit of the LGB type. As others have said above, unless there is a really specific reason for wanting to make something yourself that we've all missed, it would really seem to be a false economy....?
Paradise
28 Jan 2010
1,244
299
Back Yard
Australia
The Massoth ones also come with electrical ring terminals that attach via the 2 screws which can be used to wire up the isolated section etc.
They are much nicer looking compared to the LGB yellow bricks. :nod:
Rhinochugger
Retired Oik
4,234
North West Norfolk
I think it's probably not worth the effort - it's one of these things that, for obvious reasons, you want just right, so forget the expense and splash out :party::party::party:
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
Thanks for all the great idea's. Yes the yellow color was a negative for me, but now thanks to you all, I know of other options.
stevedenver
254
Paint, thats the ticket
Bill Barnwell
30 Sep 2017
786
549
79
Ormond Beach, Fl
I find the yellow to be helpful to see the circuit when switching from a distance, especially 10 to 15' awayold layout diaghram.JPG
Emartin
5 Jan 2018
6
Ontario, Canada
Canada
Good morning, if you have a 3D printer you can print your own, I have attached the Thingiverse file by "glatour" to do this. Enjoy!
  • Insulation_rail_joiner_for_LGB_track.zip
