Does anyone here know of anywhere that you can buy a direct replacement LGB small loco onboard decoder? I don't mean any of the LGB retro-fit types (55021, 55022 etc) OR any of the Massoth production ones like the L, the one I mean is the type that Massoth built specifically for LGB to put in the smaller factory-MTS locos like those in the digital start set? It's the same physical size as an L or LS, but has different plug connections - all the connections apart from the 4-wire motor/pickup cable (which is soldered on to the decoder) are via the tiny micro-CT plug sockets, a mix of 2, 3 and 4-pin types.
Any ideas?
Thanks,
Any ideas?
Thanks,
