stuart1955
Hi guys, can I use this thread to help get some information on which replacement axle/gear I should get to repair my Bachmann 2-6-0. I have a couple of these 2-6-0's, but one of them broke down during the summer, with all the symptoms of the failed axle gear, which I then put away with the intention to repair during the winter. I have looked on-line for the replacement axle gear, and have several options.
One being, purchase replacement from Bachmann, but I think that's a no no, as they're still the plastic/nylon type. Two, purchase axle/ gear (2223/6) from NWSL, who are now back in business, problem is, this is listed as a 24 toothed gear, as opposed to a 25 as documented by Bachmann. And although I haven't dismantled mine yet to count the existing one, would this replacement still fit and run smooth.
Option three, is to purchase a 2-8-0 axle gear, from either Bachmann or NWSL, which is a 25 toothed gear, and I assume then I would have to remove the gear off the axle, and fit it on to the existing original axle, if that is at all possible.
I would be grateful to anyone who can help or advise on this issue.
Regards, Stuart.
Regards, Stuart.
