gregh
I notice that JR inTawa has been doing trestle repairs. http://www.gscalecentral.net/HampMGR-a-family-railway-in-NZ-m9330-p29
It must be the season in the southern hemisphere!
I built my big trestle back in 1995, from tomato stakes (good Aussie hardwood) hammered directly into the ground. It consists of 18 spans, about 1.2m high, on a 2.2m radius, and a 2% grade, with a total length of 8m. I remember thinking as I was building it, “I hope this lasts 10 years”. I didn’t paint the wood, and used plain steel bolts and screws – silly boy!
Well after about 10 years, the timber in the ground was rotting so I put concrete footings around most of them, using rapid set concrete.
Now after 18 years, the top plates are so rotten that the track is holding the bridge up, not the other way round! Most of the stringers are also showing signs of deterioration on the horizontal surfaces. So it’s time to repair. Shut the line. Busses replace trains!!
Before starting on the bridge, I rebuilt all the track – it’s my ‘old’ method of aluminium bar in slotted sleepers. Then with the track strong enough to move, I removed a 6’ panel at a time and started work.
I cut the bolts with an angle grinder to remove the top caps and corbels, filled the holes and cracks in the top of the piles with Builders Bog and painted them. Then I screwed new top caps onto the piles, painting where all surfaces meet. The new corbels (8mm treated pine) were screwed on and then the new stringers screwed to them, all using nickel plated screws.
Then I replaced the track panel and moved onto the next panel.
Only one of the trestles needed major work – it had been pushed out of alignment by a jacaranda tree root.
So I dug around the root, put lots of Styrofoam around it and poured a ‘bridging foundation’ across the root using rapid set concrete, with a few bits of scrap steel thrown in for reinforcing. Hopefully as the root grows it will just squeeze the Styrofoam. I rebuilt the trestle itself and installed it just resting on the new foundation. I included extra ‘spacers’ on the top cap which can be removed if the trestle is pushed up by the root. Fingers crossed!
So far I’ve finished about 2/3 of the work. ‘Then for the safety rails’
