gregh
I built Melaleuca station in 1994, on a 3` wide by 20` long `basedboard` supported on timber `legs` at 4` spacing. It is adjacent to a large Melaleuca tree – hence the name.
Recently a 25mm high `hump` has developed in the centre apparently due to a tree root pushing up the legs. And naturally the hump occurred at a set of points to make it dificult for trains to stay on track.
So today I cut 50mm out of the two (back and front) legs and lowered it by 25mm. That leaves another 25mm for future hump removal!
So here`s the sequence.
The situation before I started. The hump is not that noticeable but it is there!
(the grey box is the now disused track power switching box. I should remove it and the wiring but I still remember lying on my back under there installing the colour coded wires and couldn`t bring myself to snip them all off!)
I installed tempory supports either side of the leg to be cut, then attacked the leg with a circular saw.
After much cursing the stuck saw blade, I managed to remove the 50mm section
I then used bits of packing in the gap and removed the temporary supports when the height was correct. I repeated with the back leg and then I then bolted aluminium brackets across the gaps
Replaced the lattice and the finished product looks like this.
This shows the profile of the baseboard before and after the work ( vertical scale is very exagerated)
And I managed to do the work without damaging anything. Amazing 8)
