ge_rik
I've had my (very) cheap Anet A8 clone for about 18 months now and upgraded almost every part of it. I've also strengthened and reinforced the structure to try and overcome a consistent problem I've had since I first got it - I get regular corrugations every 1mm or so on both the X and Y axes.
I've always assumed it was because the plywood structure is a bit rickety but I'm having doubts that it is the cause:
Rik
PS - I've fought shy of updating the firmware because my Z screws are actually M8 threaded rod rather than the posh stuff (I told you it was a cheap clone)
- I've done my utmost to eliminate movement in the structure and it has made absolutely no difference
- The corrugations seem too uniform at every 1mm or so which means the structure would have to flex one way and then the other after every 10 layers
- The corrugations seem uniform on both X and Y axes
Rik
