A progress report (of sorts)
As I had commented earlier, I had a lot of plant growth, especially where it wasn't wanted!
The worst area was a partly filled pond that I finished filling in. The reeds and other marginal plants carried on growing as if there wasn't a ton or two of rubble, soil etc on top of them!
This was a dispiriting time, as, when I fondly imagined that I had cleared them, they grew back.
In July I bit the bullet and started to dig them out properly.
As can be seen this caused major mayhem on the railway as I had to dig down about 2 feet to get all the roots out.
Bad weather, holidays, then more bad weather and work meant it was late August before the job was finished.
The gradients on the line hadn't been worked out properly in my haste to get something running so I simplified the line to be just a loop to eradicate the worst of them.
I was considering the type of road bed to use when a topic on the subject came up, after reading that I decided to use some paving flags that I had spare.
Here's a view which compares to a similar view earlier in the thread (3rd pic, 1st post).
At this point the line has been raised about 5 inches and no longer runs under the bridge in the back ground.
A couple more views showing the construction.
Danny, as usual, was the guinea pig for the new works. Here he is crossing the bridge I bought at Llanfair.
Hopefully work on prettying everything up will continue as work and the weather permits
