Annabel - The grate (or getting the most out of my darling dragon)
I have too have made the modification to my grate, it worked a treat. But I have also cut more out of my Annabel grate than what Steve has, to see how the fire would respond (the remaining front and rear cross beams). It actually proved to be a mistake, too much air got into the fire, cooling it. I've since mounted a brass strip to the vertical rear section of the grate but made it higher than what was there previously (will post a photo soon). It makes sense because on fullsize locos they have baffles that are used to restrict airflow to control the fire, so I have 'closed' the rear baffle.
Next step is to add a front baffle, but dunno if that will work as well because the mounting flange acts as it's own baffle. This leads me to think that there is a flaw in the grate design. Looking at the DJB version confirms this, 6 bars, compared to 5. The penny dropped when I realised that the 6 bar configuration would create more draft. Draft is what causes coal to burn. Reduce draft and you reduce burn, reduce burn and you reduce fire temperature. Reduce temperature and we end up with unburnt bits of coal, clogging the fire, blocking the grate, causing the fire to become sulky, or worse, go out. Now one can poke and prod a fire but this unsettles the hot base and means cranking up the blower and waiting while the fire rebuilds (speaking from experience!). In addition, on fullsize locos the grate bars are these very heavy cast objects, looking at the DJB version the bars are thick iron, possibly these help retain heat, further enhancing the fires efficiency.
I want to be CLEAR here, that I am splitting hairs (not complaining about me grate!!!), I love my Annabel, it runs a treat with session times of 1-2 hours, no problem. My goal is to get the very most I can out of my loco, spilling my thoughts and ideas here is my way to achieve that.
Your thoughts?
