R1 points
  • Thread starter Thread starter Mez
  • Start date Start date
Mez
Am i right in thinking most locos will go over r1 points ok as long
as there is a lesser radius after or a straight and before.
Seen as i see as "This wont run on R1 curves "
How many r1 curves can the longer locos go over.
If that makes sence! :D
So if you put say an lgb r1 point then an r1 curve (setrack)then straights next to your main line on a siding.
like
Sort of track diagram.
r1 curve --------------- -siding or pass
r1 point/--------------------------- -mainline
Lol Very Technical Drawing!
You could do it as you say Mez, but even a small (6") straight section between points is better than non at all :)?
Most LGB locos do. Others well I think it pays to read the details before buying one
Not sure this is the answer you wanted but r1 points are a r1 curve and a normal straight combined
so any loco will go along and over the straight bit but a lot of bigger non lgb locos wont go around the bend and that is because some with more than 2 wheels per bogie that have flanges on the center wheels ride up on the inner rail this applies to rad 1and 2 curves also. Rad 3 is ok but very tight. puting straights next to them makes no difference its the rad of the curve thats the problem
i can draw a diagram if i have confused you more
tony
Im opened minded at the moment just working out whats best radius wise(Bigger i know).
tony
Good explanation.
I even understand it.
Cheers.
Phil said:
it really depends on the size of the loco mate.......
if you had a big boy------> http://www.dragon-gscale.co.uk/big-boy-locomotive-prestige-series-diecast-metal-2148-p.asp < Link To http://www.dragon-gscale....ecast-metal-2148-p.asp
all LGB will run on R1 curves and points but others such as aristocraft, USA trains and other big american models won't run because there just too long
Cheers for link.
Sold out!
What Raduis roughly would that need as its not mentioned.
Just thinking even to get one large radius cuircit and passing loop in the future for visiting super monster sized locos. ;)
On the link, the last picture in the top row of pictures shows half a curve, stating 16ft diamater, which would be 8ft radius :)
What i have done to cut down on cost is build a "mainline" that use's rad 3 curves as a minimum it has lots of rad 1 points that big locos can go over that only smaller LGB types can turn off on into sidings, stations, passing places and branchlines its a bit like the real thing with local trains giving way to the express i have fitted 2 rad 3 points and will fit more when they turn up so that the larger stuff can park up out of the way but in the real world large express types didnt often use branch lines (yes there are exceptions) but on my railway they dont due to under investment in the track budget and it gives operational interest
the yellow lines are the center wheels and if fitted with flanges as most aristo etc are it becomes messy.
Can anyone tell me do all LGB locos have the center flanges removed i only have 2 x 0-4-0 LGBs so cant check
just to plug my video you might see what i mean. The Aristo mallet and the 66 can only use the mainline at the moment the 66 is stuck in the siding as it was placed there as all the points and curves with in the mainline are r1
http://www.youtube.com/watch?v=YwwalmeFjlc
Tony
Cheers Tony
See what you mean Tony and your thinking.
Just running the trains the right way as you do makes sence too.
I think ive read lots of times the lgb locos all go round r1
play in the axles.
Some of them do but the larger locos rely on clever articulation of the driving wheels at the mid-point and a lot of lateral play in the driving axles.
Some larger Accucraft and Bachmann locos have flangeless central drivers but a more rigid chassis. The Accucraft Caledonia has centre flangeless wheel which on an R1 runs beyond the inside/outside of the rail!
korm kormsen said:
not all locos of all brands go round R1.
but even with those, that do - are you sure, that you want to see something like this?
Cheers Korm for posting them.
Something to consider.
Simple answer - go as large as you can afford both in space and cash, even though you may not appreciate the benefit at this moment in time. You will at some point (pardon the pun!) in the future. This applies to curves as well.
Will indeed Bredebahn.
will prob go r5
This thread has helped alot.
Cheers for answers people..
