QUESTION FOR DIMAX NAVIGATOR USERS
muns
Moderator
What sort of lights? Locomotive lights, building lights, coach lighting?
Lights connected to a locomotive decoder can normally be switched on and off with button button 9 (it has a lamp symbol on it) and the lamp symbol on the display will indicate their state.
Please dont take offence, but when you use CAPITALS in your posts it is regarded as SHOUTING, so please avoid if possible. Thanks.
Greg Elmassian
8 Mar 2014
4,484
664
San Diego
www.elmassian.com
Unfortunately, when you use different DCC systems, and different decoders, not all questions are simple.
I see you have posted 6 times, all of them fundamental DCC questions. That's ok, you are clearly learning.
You might want to concentrate on either the MTS system or the Dimax system first, since you also seem to have several different locos with different decoders.
Also, have the manuals been of any help to you?
LGB333
Active Member
I HAVE ONE PRETTY SIMPLE QUESTION - HOW CAN YOU TURN ON AND OFF LIGHTS WITH THE DIMAX NAVIGATOR?
Hi - You may be having problems turning on the lights if you don't have your Massoth DCC system/Navigator set the same as the Speed Steps set in your loco's decoder. If one is set to say Speed Steps 14, and the other is set to Speed Steps 28, your loco's lights won't operate properly. Put the loco on your Programming Track and use the Navigator's Address/Speed Steps protocol and set the loco's decoder to whatever Address you want (Default is 3) and then set either 14 or 28 Speed Steps, Press Okay, then both your DCC system and the decoder should be in alignment. The loco should "jump" back and forth a few seconds after you press Okay, which indicates it was accepted ok by the decoder.
Tom
