QSI Decoder USA Trains smoke unit now working
Thirdrail68
Well after months and months of searching the tinternet and programming, tweaking I have managed to finally get the QSI decoder to work a USA Trains smoke unit.
Directly wired to the decoder, I then played around with qsi programmer.
I set up the fan onto feature output Mars light and tweaked that it was bright on fwd/Rev and dim on neutral. I applied port 9 to the front mars light.
I set up the heater onto feature output rear cab light. Tweaked it as always on and set the voltage to value 84 which is about 7v. I applied port 12 to the rear cab light.
On test. When I start up the loco, GP30 the fan comes on and so does light smoke. When I apply throttle the smoke blows out as if accelerating. I can turn off the smoke with F12. I set the rear cab light feature to output 14 to do this.
Well it works and I cannot believe it, I'm chuffed to be honest.
On test I found that the heater even though working away does not get too hot as to overheat.
Well it works for me, now the GP9 and GP38.
Happy chappie
Steve
Any chance of a vid?
Excellent bit of lateral thinking, and perseverance.. Well done.
:clap::clap::clap:
